Nav Sat System
ar_chie186
hello... yes i have an avensis 1.8 2001 with navigation system but... i have a problem how to used it... is anyone have a book that i can copy or buy pls... i need it urgently... thanksss...
i have recently purchased an avensis 01 model 2.0 SR vvti and hve been asking the same thing, having now gone through the books left me it seems that i require a CD to make this operate.
You should be able to get the instruction booklet from any main Toyota parts dealer - the part number of the manual is PZ420-ON23U-EU.
Yes you do need a CD to make the sat nav work - it should be in the box in the boot - you will need the ignition 'on' for the CD to come out if it is in there - (slide open the front of the box to make the CD eject).
If you don't have a CD then Toyota will charge about £130 for one. There are a number of ways round this - all of them illegal however.
HTH.
i have downloaded the tns 200 sat nav cd from overnet clone cd version and written this but still can not get this to work what am i doing wrong????
HTH.
Helloo, I have Avensis 2003 with TNS 300 sat navi but with out user manual. Can you send to me Toyota order code for User Manual for TNS300 in english?
Regards Veselin
arthur
What's the problem, what do you get when you turn you're Sat/Nav on?
I've got a 2002 model with ETA and gotta say next car I get with have Sat/Nav again.
John
Arthur, did you get you cd working? If so please ley me know as I have same problem!!!
Many thanks :yes:
