Tools For Oil Change?
tallguy
About to change the oil on my 2008 Avensis (2.2 D) Can some one tell me what Socket sizes I need, main drain plug, Filter housing drain plug and Filter removal?
Any help much appreciated :thumbsup:
Tallguy
filter should and can be removed by hand
unless its glued to the engine block then you will need a chain
a wrench with
10mm 12mm and 14mm will be enough :)
a wrench with
Are you sure about the filter? I know its not a spin on/spin off type. I think there is a cap with a drain plug in the middle.
a wrench with
Nope!
Id like you to correct me if I am wrong tho :)
