Power Steering On 2003 D4D
carday
Anybody any ideas on why the power steering has started to feel heavy, there also seems to be a sound when turning the steering wheel,
pump functioning okay, power steering fluid reservoir okay.
Some possible causes of heavy steering are:
- Tires (Improperly inflated)
- Power steering fluid level (Low)
- Drive belt (Loose)
- Front wheel alignment (Incorrect)
- Steering system joints (Worn)
- Suspension arm ball joints (Worn)
- Steering column (Binding)
- Power steering vane pump
- Power steering gear
- System may need bleeding when foaming or bubbles observed in the fluid reservoir
BTW, how do you know the pump is functioning OK?
