Hi
Which ENGINE oil is type should I be using in my Toyota iQ2 Automatic
0W-50
0W-20
or ??
Please advise
What does your manual say?
he cant reed or right
May be I should re phrase the question - to read "Which Engine Oil" do you use??
The manual is not clear - it states several grades ??
It's absolutely clear.
It says: use 0W.....
OR if not available:
Use 5W .... BUT change asap to 0W......
For Centre Europe 5W-30 is fine.
Here are the ranges
below -35°C 0W
-30°C 5W
-20°C 10W
and W-30 is for plus 30°C
W-40 for plus 40°C ;)
correct, but Wxx doesn't mean xx°C
