Changing Brake Discs And Pads - From Guide On Site
jrb1512
Ive been trying to remove the pin bolts on the calipers for 3 hours argh, the top one is loose but i can loosen it over and over but it never comes out are they supposed to come out completely from the assembly? help please.
Yes. Grasp the end with a mole wrench locked on hard and pull while turning...
you need to hold the square flat with a spanner while turning the bolt.
