Rear Diff Bush
ajcluck
hi all, my rear diff bush has split and when i went to order a replacement i was shocked at the £100 price tag. is this correct, if not where do you get them?
About time you came back aj, hows the car. Are these what are after....
http://cgi.ebay.co.uk/REAR-DIFF-BUSHING-KIT-CELICA-ST205-GT4-GT-FOUR-/300419850086?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item45f26b1f66
He's a good guy aswell a lot of people use his stuff, i have 2 of his engine mounts.
Cheers Fawbs,
yeh been studying so not had much time for the car as of late.
She was great up until yesterday afternoon when i started hearing a cluncking nosie which resulted in a knackered bush! still to get the final map.
hows your beast coming along?
Almost done, will be starting her up on wednesday/thursday with a bit of look. I see what you mean about clocking your turbo, i could only just clock mine enough to create the intercooler route, clutch nipple came close.
Yeh pauls stuff is pretty much direct fit and they are better than the standard ones so its a good buy, they usually take around a week to come.
yeh i was gutted, i really wanted my turbo outlet facing down but no joy! haha the first start up, i was a tad nervous when i turned the key!
is it an easy/quick job to replace this bush?
I have no idea, don't think its too hard, is it definitely a bush not the mounting plate?
yeh deffinatley the bush, split right down the middle and the diff has dropped a couple of inches!
rear diff mount is a doddle to change. all you need are spanners, sockets, jack and axle stands.
try Trevor at TCB for one as well.
