Gen 7 Digital Clock
reeno10
Hi all. I got my celica 3 days ago and my clock does not seem to be working. It has lit up twice in 3 days. I think it may be the bulb but I am not entirely sure. Can I take the clock out without removing the entire centre console? If so any tips on how to do this would be much appreciated.
Cheers
Cheers
Hey there,
Nope, the centre console has to come out... here are some instructions for removing the middle console - it looks harder than it actually is and will literally only take you maybe 10 mins to get it off. Which will expose the clock and give you easy access to it..
I doubt its the bulb thou. Id check the fuse first. Perhaps simply disconnecting the cable running to it and re-connecting might fix the issue if there is a break somewhere or loose connection.
Heres the link:
Removing centre console..
Hey there,
Heres the link:
Thanks for all your help. Removed the clock and it is the digital display that is faulty. Anyone know where I can get a replacement clock?
Cheers.
