hi just want to know what psi does the gen2 mr2 hit the fuel cut
about 13psi I think ..
not high enough. with a fcd it'll hit higher, not sure when mine cuts in, just know it's above 25psi on mine ;)
have you modded your turbo i thought that the stock turbo melts at 1.1 bar
The workshop manual for the 3SGTE Celica says its set at 11.8, and i'm fairly confident its the same for the MR2. However this is measuring absolute pressure which is slightly different to boost pressure...
matt.
matt.
That's what I get too. Made a $25 fcd for my Gen II when I had it...worked fine. Supposed to be 18.? on the Gen III but for some unknown reason mine doesn't cut......about 22psi is the most Iv'e seen :)
Cheers
KiwiMR2
