Maintenance Manual
richteex
Does anyone know if theres a haynes manual or similar for the 2007 diesel engines. I cant seem to find one anywhere.
Nice one Timson - you don't by chance have a similar link for the 98 to 2000 model ?
Most of the stiff you might need can be located here: http://www.toyota-tech.eu/
A couple of pound gets you an hours access which should be enough time to get all of the relevant bits you might need, and its direct from toyota.
If there is anything specific you are after you can also have look through the forums here as there are quite a few handy and helpful threads.
