Gen 7 140, Water Under Rear Seats
xEla
Hi all,
at first i thought that somebody left open 1.5l bottle at rear seats...
Now it's been raining for a few days - and there is a lot of water under the rear seat passenger side..
i've opened the little hole under the seat to let it out....
i cannot sea any visible water tracks....
where could be the problem?
I have a sunroof...
P.S. the other seat is a little damp too...
Guy,
none has even an idea pls?
Check the boot seal, especially near where the centre 3rd brake light is. When I had a little drip there it turned out to be a bit of a twig breaking the seal.
Is there any damp/water in the boot?
Guy,
yes there is sometimes water in the boot (under the spare tyre) – but haven’t been there for some time...
the water track is coming from driver side rear lights... it cannot go to salon really...
I did not see any water tracks coming from middle break light… where should I check?
It quite a common fault to have water leakage from around the rear lights, it appears that some cars were assembled with the gaskets not placed correctly + a couple with no seal at all.
Look in the boot access panels used for replacing rear bulbs & you'll see three 10mm nuts holding each tail light cluster on. Take off each light & check the foam gasket is present & not creased up or anything, a 15min job at most :thumbsup:
What he said +1
