Verso 2009 - How To Remove Driver's Airbag?
I can not understand how to remove driver's airbag ... Any screws behind steering wheel, as before, was not found. There are only two small holes with a diameter about 3 millimeters. Probably there are catches, but I can not see them ....
You must take two sticks, for example, like for Sushi. And insert those into that holes. The Airbag with Signal knob then can be taken away.
