Load Sensing Valve
bess
my car has lost the spring loaded rod from the rear axle that operates the load sensing valve, anybody had the same problem, toyota will only supply both parts, but there is nothing wrong with the valve.
checked the EPC and the valve is only available as a complete unit as the dealer said. it may be possible to source a second hand one from the breakers and swap the missing part over
