T-Belt Warning Light
yetihere
Hi
I do not have a manual and the T_BELT warning light has lit up on the dash, what does it mean, does it mean the timing belt is knackered and I should not drive it or does it mean it needs adjusting or what does it mean, Can I still drive her or should I park her up !!
Hi
Hi mate, :)
The cam belt needs changing every 60,000 miles,or 100,000 km, do you know when it was last changed?
If not, change it asap. BTW you don't say which surf it is, 2.4, 3.0, hope this helps.
Gman.
  • 7 years later...
HEY THERE,
I have a Toyota Hilux that I have just serviced and the T-Belt was replaced. But the T-Belt light is still on. what does this mean?
it a 2015 Toyota Hilux DC 2.5D
It means whoever did it didn't reset the warning light!
Can't speak for the newer stuff, but on the old Surfs you had to take the instrument cluster out and swap a screw over. I'd imagine it'll be done by computer now.
  • 2 years later...
hi i was driving on western highway on sat and the tbelt warning light came on--the van didnt stop and it didnt overheat-what does that mean
Edited by stephendgray1958@gmail.com
wrong spelling
It's just a reminder that it's time for a new belt.
  • 1 year later...
After starting my Hilux vigo 2006 model 3.0 L, I saw the T-belt light on the dash flickering for a few seconds and the Fuel filter indication comes on momentarily and then disappeared. What could have caused this?
  • 8 months later...
Hi, I didn't manage to sort mine yet, removed the cluster and Battery terminals, checked fuse box all sides for faulty fuse or burn out ones..yet trying to sort .do you mind if we can share our findings on WhatsApp?
Hi, did you manage to sort flickering t belt light as my Vigo behaving the same Way
