A Favour From Any 4.2 Xt5 Owners
Catweazle
A friend of a friend (ask no questions) has offered me a Toyota radio\satnav for £500. He assures me that it is working, includes the map DVD but may need the original CD to boot it up. Would one of you kind 4.2 XT5 owners be able to have a shifty at the model number on your unit (bottom right hand corner) and tell me what it is? Also, is he right in telling me that I need a CD to boot it?
Finally, anyone know whether it will be a straight swap for the unit in my XT4 and does the XT5 one show the MPG, average speed etc, as my XT4 one does?
Hi Catweazle,
1) B9001
2) The Map DVD should boot the Sat Nav. I did'nt have a seperate CD with mine.
3) Not sure if it is a straight swap for the XT4 unit, but you will lose the MPG, average speed etc., info. which is a bit of a bind.
Hope this helps.
Hi Clive
Many thanks for the info.
Does the XT5 unit not display the MPG, speed details then or do you have a separate display for this?
It does not display them, A bit of a con as the XT5 is advertised as having it.
Also make sure the DVD is the origonal. And it would be nice if it was upto date 2009-2010
But in all honesty, I would not miss the sat nav if i did not have it, A tomotm is just as good if not better.
