B9004
tatteam
Can the onboard GPS system, B9004,be modified to read Garmin maps?? :driving::g:
In Malta?
Yes, all you have to do is open up the unit, reverse engineer the PCB (printed circuit board) - i.e. trace out all the signals and produce yourself a schematic, find out which microcontroller is used (probably something by Renesas), get yourself a compiler for it and re-write all the firmware. :P
Seriously, no, I can't see how they could be used. The B9004 map format I believe is based on specs from the kiwi consortium:
http://www.kiwi-w.org/index_eng.html
Quite a lot of auto units are based on that. There are various attempts on the web to reverse engineer some of the map dvds. Don't know of any significant progress - haven't looked recently.
The newer hard disk based units are worse. Rather than just upgrading the map DVD, it has to go into a dealer to be done allegedly.
Cheers :thumbsup:
Thanks,
it's a pitty I can't install amap which covers my country, MALTA. :crybaby:
