corolla gti rear fogs
gavdidit
does anyone know if the fogs in the rear clusters were put into both sides on the later models?
i've got an '89 and its only on the drivers side!
i want to re-wire them so my fogs work as extra brake lights and get the fogs in the bumper ( possibly a custom job)
any comments would be welcome
All Corolla's had one fog lamp
The only way to do it it to order a LHD spec cars rear lamp assy
or order a set of rear clusters from www.autostyle.co.za for bugger all money, all clear, semi-clear or stock and all come with wiring loom and blulbs attached. They dont get much fog in South Africa so they dont run Fog lights and the section you want to use as extra brake lights is......wired for extra brake lights. Not only that it'll cost you about £30 for both light clusters etc :D
In South Africa there are more Corolla's on the road than there are FORDS in the UK ! but they have different model names so make sure you order for the right car, their equivalent of out Gti is a 'conquest'.
Hope this helps.
