Petrol Cap Is Not Opening From Inside Switch
jaison
Hi
Can anyone help me reageding petrol cap is not opening from inside switch, i mean from door electric switch. Can i know is there any fuse for the particular switch. Thanks
Hi
The fuse is No 64, 10amp in the instrument panel fuse box. If it isn't the fuse it could be the solenoid that operates the plunger on the lock or the plunger has become detatched. Open the flap manually and get someone to operate the switch and watch to see if the plunger moves. If not, the mechanism can be accessed by removing the side lining in the boot.
Fitter
Hi
Fitter
Hi Thanks for your reply, i checked the plunger mannualy with Battery its working well, i belive its becoz of the fuse, but i didt find the fuse box, only i can c the fuse diagram inside flap, inside no fuse pannel. for finding the fuse pannel do i need to remove more pannels inside or not ??? thnaks
The fuse box is on the right of and below the steering column.
Fitter
HI today i checked my car with a local mechanic, as perh im he find all the fuses and all working and also checked the plunger with direct to Battery its working. But when he opend the switch there is no power supply, still he is not getting y the power is not coming to the switch area. can you find the soluton, thanks
