Front Wipers On 2001 Avensis Vermont
ncc98071
Hi
I have a 2001 Toyota Avensis Vermont Diesel, Hatchback and the front wipers are not working. nor is the washer, was working fine but stopped yesterday morning on me.I am guessing that it is a fuse that is gone, C
Can somebody tell me where the fuse box is on the avensis and also do they have the layout of the fuse box
I am not very mechanically minded!!
The rear wiper has never worked on car since I bought it so may be just a fuse as well
There are two fuse boxes. One is behind the small storage compartment below right of the steering wheel. There should be a map on the back of it. The other is in the engine bay near the Battery. Again there is a map inside.
cheers funkg, it was located in the small compartment box beside the steering wheel, replaced fuse and all working fine
cheers
  • 4 years later...
Thanks for that advice, mine went this morning, found the hidden fuse box, checked the 20 amp fuse, it had blown, so replaced with only spare fuse big enough (30amp) & all is working fine, but will change back to 20 amp fuse when I go to the car spares shop this afternoon, regardfs to all great site & so helpful, just don't know how I could keep the old girl running without you all
