Fuse Blowing
relentless
hi all
7.5 amp fuse that controlls centrallockin/alarm/radio keeps randomly blowing which means i have to unlock using key which then sets off alarm. when i replace fuse it can last a few days or only a few hours and no one thing seems to blow it ie it does not blow when i open a particular door.
hi all
Sounds like you have got a connector, joint or door soleniod partially shorting out.
Looks like you need to spend some time with a good multimeter, the wiring diagram and try and isolate which door (probably) is causing it.
Don't be tempted to slam a bigger fuse in otherwise you may burn out things and even catch fire if you were unlucky.
hi all
