Hey guys,
I would like to replace the panel filter in my Aygo and I was wondering if anyone has any good recommandations. I know there are plenty of companys who make replacement filters such as: Blitz, BMC, Green, K & N, Pipercross etc. But which ones do you use, which companys do you prefer?
  • 4 months later...
Hey guys,
K & N, and Pipercross, and Green, are well known. I have a £40 Pipercross one, and having done 9000 miles, I am going to have to wash it in warm fairy liquid solution, and rinse it several times in plain warm water, before letting it dry in the draught from my garage window. Then I will have to very carefully spray one side with special light oil that came with it. Too much oil, and the lambda probe can get oiled, and give duf readings to the ECU. (perhaps I should have stuck with cheap throw-away standard paper ones.)
I think opting for a 'performance filter' for the Aygo is overkill. Jsut keep the standard genuine Toyota one and repalce it often.
