B Pillar Panel Removle
TruBlu
Hi all
Has anyone removed the inside panel on the drivers B pillar - where the seat belt enters?
If you have, can you give me any tips on how to do this.
Hey Tru!
I've removed only the black part, not the top white. Here's how it goes: Remove the black plastic sills from front and rear by pulling them up. Then just pull out by pulling towards the seat the black plastic of the pillar. If you want to remove the top part too, I'm sure you'll be able to figure it out after removing the bottom.
Hey Tru!
Thanks for that info. The top white part is held at the sides under the door seals by some tags but it's the top part that bothers me - I wouldn't want to just pull it off as I may break something. Anyway I'll investigate it with some caution. I'm still trying to get rid of the rattle/wobble sound that seem to come from that area but now I've noticed that when the drivers window is down the rattle seems to disappear - now I'm wondering if it's something to do with the window or door. Thanks for your help anyway.
Trublu
at the bottom of the 'B' pillar white cover you'll find 2 screws; remove them, then take a screwdriver wrapped in some tape, and release the upper latch.
at the bottom of the B pillar white cover you'll find 2 screws; remove them, then take a screwdriver wrapped in some tape, and release the upper latch.
Thanks for that info. The illustration was really usefull.
TruBlu
