Best Place To..
oMIKEYo
Just finishing off my boot build, will post pics later but...
Whats the best place to attach a RCA adapter to? (Using standard head unit for now, but may aswell keep using them when upgrade)
Whats the best place for the remote wire? (cig lighter?)
Whats the best place to feed power to Battery and also to hide the wires?
Whats the best place for the ground?
Pics would be good, if possible
Cheers
Mikey
the remote wire should be part of the wiring harness.
best place for the ground is anywhere that you can screw it into, so long as the bolt has bare metal
never used RCA adapters so cant help you there i'm afraid
