Rav T180 Large Diameter Discs
Big_Stu
I want some front discs (and possibly calipers)for my Rav 4 T180 that fill the space in the wheel and can cope with the braking forces without warping - is there anything?
You can fit regular discs and aftermarket pads as it is the original Toyota pads that cause the warping. Remember that very high duty can cause the discs to warp but that isn't the same as the "normal" judder.
Do yours judder now?
You could try here..LINK but most seem to be POA,you can even get Brembo discs + pads if your feeling really flush.. :thumbsup: Stew
Theres loads of options for changing out discs... funny shapes like rotordisc; dozens of drilled, grooved etc discs from various sources...
or
you can get custom built ones like I did - as I needed larger discs and calipers.... expensive and I also had to buy new alloys to suit the new calipers size.
Comes down to how much money you want to spend.
