Door Card
speed machine 1
hi i have a gen 7 ceilica does any no how to remove door card so that i can have a look at electric window as it does not work many thanks pete
Hi, if i remember right, a triangle piece behind the mirror pops off, then there is a small panel behind the release lever then a screw, also the grab handle should have a insert to remove and have 2 screws behind it, possibly a screw behind the door light(if fitted), the rest are poppers so just a good tug on the bottom edge should get things moving, hope this helps.
Hi Pete
Which window isn't working - Is it the passenger side?
If so, you may have accidentally activated the window isolation switch near the ignition barrel
Just press it once to activate, once again to de-activate
