Avensis 2.0 Gls Abs Light And Lack Of Pwer At Low Revs
Bango
Hi Guys, hope somebody can shed some light on a problem I seem to have.
A couple of days ago my car seemed to struggle when I put my foot down in relatively low revs (2-4k). It does this in most gears but is more noticeable in higher gears which is a pain on motorways. If feels a bit like when you try and set of in a too high a gear.
Also today as I was driving I noticed that the ABS light has come on and remains on permanent. Im not sure if this is linked to my other issue or is just a coincidence.
The car has done quite a few miles (170k) and is still on its original clutch e.t.c.
If you need any more info let me know.
Andrew
Andrew
It may be worthwhile checking to see if you have a hot wheel after driving as the combination of an indicated ABS fault and sluggish performance point to a brake sieze possibility.
Fitter
Andrew
Fitter
Cheers Fitter, I'll have a look next time I'm out. With regards to the ABS light I have been keeping an eye on it and it seems to come on after I have been driving for a few miles then remains on for the rest of the journey.
Cheers
Hi, just thought I would update the thread to le tyou know what the issue was. Ended up taking it to a garage when it was diagnosed as a cyclinder misssfire. Had new HT Leads and plugs and power issue back to normal but still getting the ABS light.
