Avensis D4D Duel Mass Flywheel
toytoyota
Hello can you get a single mass flywheel for a 2004 avensis d4d.I have seen kits for older models (will these fit) can anyone advise me of the best and cheepest way to go about this. Thanks paul.
Hi there,
I remember some time ago there was a discussion about exactly the same issue. IIRC the thing you would need to remember is to change your driving style to prevent the transfer of torque that is taken care of when you have the DMFW in place.
If you search around you will deifintely find it, it was in 2010.
Good luck!
First check compatibility of DMF kit that Anchorman has listed for sale on the Rav4 section, just in case you can replace with new OEM parts much cheaper.
Big Kev.
