I have a Toyota TownAce CR-27 (YOM 1984) with a original 2C (non-turbo) engine that came with the vehicle.
About two months back, it developed a problem with the engine where the engine used to startup normally in the morning. It did not start-up after the engine got heated after running a short distance even. Then the only way to startup the engine was to keep it to cool off for about 30 minutes or so.
The situation became worst when the engine ran for a slightly longer duration and the cooling time also increased.
Since this issue was driving me crazy, the mechanic I spoke to told me that my engine is under compression and that it needs a complete repair.
Going be his recommendation, I did the complete repair and the following were also carried out during that process:
- New Piston Rings (standard size)
- New Timing Belt + Adjusters
- New Oil Pump
- New Water Pump
- Phased Engine Head
- New Valves
- New Shims
- Valve Grinds
- New Gasket Set
- New Diesel + Oil Filters
- Complete inspection and service on the Injector Pump
The things that were not touched included:
- Used Same Pistons (standard size)
- Did not bore the engine as it had a standard set sleeves from a previus repair
- Same engine head but have done a phasing of the head unit
With all the above taken care of, now I'm at a loss to figure out why this engine is still heating up the same way it did before the repair.
I read on a few internet forums that this (or similar) heating problems could occur due to crack(s) in the head unit of the engine.
Any advise and direction to get this repaired is much appreciated.
Thanks in advance.
  • 1 year later...
- New Oil Pump
- New Water Pump
- New Valves
- New Shims
- Valve Grinds
- New Gasket Set
Thanks in advance.
hi, i think what you should have done is replace the liner and piston rings because it seems that the you ve not attained a good compression in your engine and its important to have a high compression since thats the life of a diesel engine.
I think that you may have a couple of problems, one being low compression causing your starting problem. Secondly, a known problem in the 1c and 2c engines was cracking in the cylinder head. It may be worth having a compression test done now to see what your engine is actually like but ultimately, i reckon that you may have to have the head removed, pressure tested and possibly repaired by deep welding into any cracks and then machined.
Have you looked into the radiator to see if there are any bubbles which would be a tell tale sign of pressurising?
Has the thermostat or water pump been checked?
Dont jump to any conclusions, start with the easiest options first and rule out these.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
