Aygo Bluetooth Multi Mobiles
how many mobiles can you connect to the aygo bluetooth system, and will it connect to the multi mobiles automatically ?
I have four mobiles set up, two private and two work phones.
Most bluetooth systems will pair with 3 to 10 phones, automatically connecting to one of these when
you switch on ignition and having BT on on the Phone (the phone does NOT need to be "discoverable"!)
In most cases the last connected phone is tried first, when that doesn't connect
the other ones are tried in the order they were paired with the system.
A Very limited number of systems (like the Bury CC9060) support MultiPoint bluetooth, allowing you to
connect TWO phones at the same time, both giving automatic control on incoming calls toe the carkit.
And you need to select which phone to use before making a call yourself.
But the various systems the Aygo has been supplied with don't do this...
