Rear Door Stuck In Lock
bisto
Hi, I've a 2006 Prius and the rear driver side door is stuck in lock. I can't open it with the remote or manually. Called local Toyota garage and they said it will cost c.£50 just to run a diagnostic check. Anyone else have similar problem or suggestions for remedy?
