Intermitent Power Lose Under 2000 Rpm
shoey100
need help ive had this problem since owned it was intermitent at first now more offten no error codes recorded local garage thinks its air flowmetre ..its now doing me head in ...any help please
hello
clean both MAF and trottle first + check again.
Cheers/Igor
hello
Cheers/Igor
hi thanks for that info mate but could explain what it intails. many thanks...igor..
Easy to do.
1. Remove the hose connection from air filter to throttle body
2. The MAF sensor is that black unit on top of the air filter housing, remove the connector, bring out and clean
3. Get carburettor cleaner and spray to clean the throttle body and IACV.
Reconnect back in the reverse orders.
