Electric Windows And Sun Roof Not Working.
barking mad
The windows and sunroof suddenly stopped working. The motors are ok as I had to use an external 12v supply to close one. The drivers window works! but none of the others do. I dont think its a fuse problem as one still works but is there a relay or switch between the drivers door control and the rest that could be faulty? Does anyone know what might be causing this fault?
