Abs Problem On 2005 2.0 D4D - Any Ideas?
peanutome
Avensis, 2005 2.0 D4D, has just failed its MOT because the ABS light does not light up when the ignition is switched on. It should come on and then go off again after a system check, but it does not light at all. Stamped on the brakes on the way home and the ABS defo works.
Its in at Toyota tomorrow for a diagnostic, but are there any common faults in the system that it could be - Just want to prepair myself for the sort of money and work involved!
Any suggestion?
David
