Oil Feed Pipe Gasket
aderiley
Hi all after some advice , i have a recon ct20 turbo on order as last replacement lasted 7 mins dohh can you tell me which way rounfd the metal turbo to oil feed gasket goes ie the square edge on the left if leaning in to engine bay or doesnt it matter? thanks
it doesn't really matter i don't think, one thing i do know is they are ment to be single use gaskets so if there is any damage at all to the coating it'll need replced for sure
