Tte Compressor
P-J
Hi All
Just signed up and been through the site and like what I see. Just wanted a quick post to start me off, I have a 2006 TTE Compressor Corolla and just wondered what would be the best way forward to improve its performance.
Any suggestions would be most appreciated.
Regards
Simon
get a typhoon kit on it! :) i got a tte compressor a week ago, typhoon kit fitted a few days ago big BIG difference .. so far thats all i know
Have a look through the Corolla section.... plenty of threads on the most common upgrades ;)
Where is the best place to buy a K&N Typhoon kit and how easy are they to fit.
Regards
i got my one at Halfords of all places :wacko: did search the web but Halfords was £40 cheaper then the sites i checked but best to check around . the distrutions arnt reall easy to follow and you have to cut some wire to the mass air sensor to add some extra length to them or you end up with the problem a fellow toc member found out when a few wire broke at the connector end..
i got my one at halfords of all places :wacko: did search the web but halfords was £40 cheaper then the sites i checked but best to check around . the distrutions arnt reall easy to follow and you have to cut some wire to the mass air sensor to add some extra length to them or you end up with the problem a fellow toc member found out when a few wire broke at the connector end..
if i was a haynes manual id give it 3 spanners lol
This section is for new members to introduce themselves. Please do not ask questions about your car here.
All the info you need about filters etc is in the Corolla section ;)
