2004 Avensis Estate Rear Washer Not Working
chimp1965
As per the title.
Am wondering if this is a common fault. If yes, is it likely to be the motor or something simpler?
Any other common problems known?
All help mucho appreciato.
As per the title.
If the wiper is working but not the washer the fuse will be ok because they are on the same fuse No 38 20A in one of the engine comp. fuse boxes. If you can hear the pump runnimg it could be a blockage or if not it could then be the switch, wiring or the more likely the washer pump in the fluid reservoir. You will have to get underneath to get it out and connect it directly to the Battery to test.
Fitter
