Cam Belt
Dougal797
Hi I seem to have a problem on a 30k mile car. A local garage changed the belt for me and now after 500 miles or so there is fraying on the right hand side of the belt any ideas would be greatly appreciated.
Did your local garage use an original part?
In any case, I would go back and show them the result.
Fraying after only 500 miles is not normal, for any belt.
BTW, 30.000 miles for the first(?) belt is not normal either. :unsure:
ANY PICKS HOW BAD IS IT IF ITS NEARLY HALF THE BELT I WOULD SUGGEST CHECKING THE CRANKSHFT SLIPPER RING WAS REFITTED THE RIGHT WAY AROUND
