10K Boost With Yaris T Sport Maf Sensor
mickyellis
Hey all,
I want to put a can of 10k Boost through my GF's T Sport. With my EK9 Type R i just pull the intake pipe off the Throttle Body and spray...jobs a goodun. With the T Sport you pull the pipe off the TB and the engine cuts out. Now i know this is down to the T Sport using a MAF in the intake stream intead of a MAP in the TB like my Honda does.
But here's my problem you spray 10k boost post MAF but how do you do that if it cuts out when you take the pipe off after the MAF?
Any ideas, im sure you guys have done this before?
I dont know what this stuff is but it it coats the MAF sensor strip inside its bound to cause trouble, a MAP isnt as exposed as such.
