How Do I Replace The Pollen Filter In My Corona Premio
Stavros0
Hello Wise Ones
I have no manual for my 1996 Corona Premio, and the Air Con is becoming toxic - I think it needs cleaning. How do I replace the pollen filter, and what else should I do to restore it to a healthy state? It still cools the air well, but the output is certainly not "clean" air.
Thanks in advance,
Stavros0
usully the pollen filter is situated behind the glove box, if you open glove box there should be a screw, remove this then if you look behide glove box there should be a retangle box. open this, and remove filter. also you could use an air con cleaner like this http://www.halfords.ie/webapp/wcs/stores/servlet/product_storeId_11101_catalogId_15551_productId_224996_langId_-1_categoryId_212466 hope this helps.
