Yaris 99 Gs 1.0 Possible Air Leak?
James Watts
This problem has been coming and going.. basically theres been a really annoying whistle occuring under the hood whilst im driving.. Its only when the car reaches cruising point, if i put my foot down a bit more, the noise goes until the car is cruising again. Ive been hunting around with my WD40 can spraying the odd bits but no luck. It appears to be coming from behind the engine below the car near where the steering mechanism is. The car still drives as it should do no problems, its just the noise which gets on your nerves after a while.. Any help is much appreciated :)
Heres a link to a video i recorded to give you an idea on what the noise is..
