Replacing Speakers + Upgrading System
ANONGMUSIC
Dear Toyota Owners!
As you can see, i'm new to this community so i'm not really experienced concerning forums and such as.
I've got a Toyota Yaris 1999/2000 and ive bought a soundinstallation to build in my car, since i want great music!
I managed to replace the standaard 6-disc radio by a Pioneer DEH-5200SD and ive connected the subwoofer + AMP.
now ive got a problem concerning the Speakers in the front doors. These are 16cm Speakers and its not a problem to replace them, only im having problems with the wires! I was going to ONLY replace the Speakers and use the old/standard factory wires that were connected to the old speakers to connect to the new ones who got 80watt performance. Now im not sure if this is the right thing to do? Does the wires matter or do i have to replace the whole wire set?
BTW: does anybody have a tutorial on how-to do this with the wires?
thanks in advance,
ANONG
There should be a fitting guide to ALL Speakers, somewhere on this forum as someone loaded them after doing theirs.
I think they had AUTOLEADS connectors that transfered the Yaris wiring to standard speaker terminals and also the same maker's adaptors to fix their Speakers as depth of speaker is quite crucial so as not to foul the window mechanism! Look up the how to guide3s or type in AUTOLEADS and see if you can find the guides. If you can't, I will look myself and advise you as I have been around some of the sight and may have more luck.
Gar.
Hey!
Thanks for your reply but ive been searching without succes! couldnt find it..
btw.. ive already got the autoleads connectors.. i just need to know about the wires connected to the Speakers
