2000 Model 2.0 Cdx - Starting Problem
steviemac1970
Hi All,
Can anyone tell me where I will find the starter relay on my car? It is a 2000 model Avensis CDX estate, 2 litre (just pre - vvti).
When I turn the key it either fires first time, just kicks over or sometimes does nothing at all - just want to eliminate the silly stuff first.
From the driver seat, the click seems to come from somewhere in the glovebox area (or at least from that side of the car). Not sure if it's
located in the box of fuses and relays under the bonnet, or if so which one?
Thanks in anticipation,
Steve
stevie boy...
welcome to the forum
go into the avensis section of the forum and you'll find/get an answer from one of the avensis chappies.... or maybe a modeator will kindly move yer post to that section, when they awake
