Does A Yaris Mk2 D-4D Have A Map Or Maf Sensor?
siray123
As above.
I have seen the top (top plastic) of the sensor but unsure if its a map or maf sensor.
Cheers
It's a MAF. Here is an example of one:http://www.irishautoparts.ie/iapmaf01631.html Not cheap!!
Hiya mate, thanks.
it was only 'slighty' dirty after 40k miles.
I cleaned mine using a bit of tissue paper rolled into a point. The bulb bit had caked up a little so it might not have been reading the air temp properly. I didn't notice an improvement but it's good practice i suppose!
I also dropped one of the screws and had to remove the undertray to get it back. AAAGH! Typical 5 minute job turning into a major job!
Same here, the bulb bit was slightly caked up, doubt it will make a noticed improvement.
