2.0L In A 1.8?
Tay
Hi all,
I am considering changing my 1.8VVTi due to high oil use, and was thinking of putting in a recon 2.0L i have seen.
Is that possible? Is that easily done, or is it likely to significantly increase the cost/time involved?
you will need the engine and ancillary's as well as the engine loom and ECU. unsure of the gearbox it depends on what engine code it is. also getting the engine mounts will be helpful
if it is an engine from the same model avensis then should be fairly straight forward
