Low Oil Pressure On Sr180
Andy SR180
Yeah. Sorry it is low oil pressure. DoH !
I used this stuff to top up :-
http://www.carlube.c...emi%20Synthetic
It is about 600 miles overdue for its service though.
Cheers
Andy
Tbh I dont know a lot about this oil. I would only use a full synth in my car, but thats just me. The problem that you have with any semi-synth oil is you just dont know how much synth is in it! It could be as low as 20% may be lower. Does this oil meet the C2/C3 spec for the D-CAT and fuel economy? How much did you pay for the oil? Did you know that you can get Mobil 1 ESP for around the £26 mark for a 5ltr tub?
I only used that oil as a stop gap till the service it is ACEA-B1 which it states in the manual is correct for the engine.
I was considering using C2 at the service due to the low ash level and I thought it might stop the EGR clogging up so quickly after just cleaning it.
Even reading this thread there seems to be some debate over which oil is best for the 2.2 DCAT engine, like certain manufactuers saying don't use this anymore use this instead. I wonder if anyone has had a definitive answer from Toyota on which oil is correct.
As it says in the manual use C2 ( or B1 if C2 cannot be obtained ) on the 1AD-FTV engine or you'll damage the cat, but on the 2AD-FHV (2.2 DCAT) engine it advises to use B1 and mentions nothing of C2, but C2 would most likely be better.
Oh well I will get the car serviced next week, maybe I am putting too much thought into this ;-))
Cheers
Andy
Cheers
Andy
There are so many different views on the specs (Which is not helped a lot with the owners manuel sometimes) on here that its just a case of making your own mind up in the end. Some dont like synth oils and prefer to use a semi synth. But I like to cover the bases and use the best synth that covers all the specs as it will have a better "Flash point" and TBN number in the most part.
I think a "Low ash" content oil with help maintain the DPF which is a very expensive part to replace. So for a few more quid I feel better using a C2/C3 spec as well as running the car on Shell V-Power derv and using BG244 every 10k or so.
Now I'm putting to much thought into it! lol :wacko:
Ive used Comma oils in my other cars and its been pretty good but never in the T180. According to the spec sheet this oil should do the job
Comma Oils
PROTECH 5w30
APPLICATION
• Fully synthetic high performance 5w30 low SAPS oil specially formulated for the latest petrol and
diesel vehicles fitted with exhaust after-treatment units that require an ACEA C2 grade.
• Do not mix this oil with other types of oil, as the requirement for exhaust after-treatment
protection will no longer be guaranteed.
SPECIFICATIONS
• SAE 5w30
• ACEA C2
• API SM CF
TYPICAL INSPECTION DATA
Specific gravity at 20°C 0.848
Viscosity @ 100°C 11.1 cSt
Viscosity @ 40°C 64 cSt
Viscosity Index 169
Viscosity CCS @ -30°C 6100 cP
T.B.N. 7.0 mg KOH/g
Sulphated Ash Mass 0.7%
Zinc 0.09%
Calcium 0.17%
Phosphorus 0.09%
