Part Number Crankshaft Positionj Sensor
peterc.lewis@blueyonder.co.uk
Ordered a Crank position sensor from a "national" network of breakers.
It is evidently NOT the right part as it is too long. I know because I've got the timing belt covers off and it is touching the toothed wheel before the o-ring is even starting to go in the hole.
The one I broke off has something stamped on the side , it reads :
TOYOTA
90919-05011
029600-0211
4t15
The one they sent has
TOYOTA
90919-05030
029600-0755
4f22
Does anyone know
a. Which is the part number on the one I took off
b. out of interest what car the sensor they have sent me belongs to.
c. the one sent is dented on the face where someone has pushed it out of the housing . Would this have broken it ?
Cheers,
Pete.
TOYOTA
90919-05011
029600-0211
4t15
TOYOTA
90919-05030
029600-0755
4f22
Does anyone know
Cheers,
Pete.
Hi Pete,
I just checked the ToyoDIY.com site, and can confirm that 90919-05011 is the correct and only part number for the crank position sensor.
The supplier has to realise, a similar part may look identical, but will not be electically compatible.
I have been reading your recent posts with interest, as I have the GLS version of your car.
Good luck.
Konrad
