Does anyone know what to do about the slider for the front sun-roof (Manual) is stuck closed and i cannot seem to pull it across so i can open the sun-roof.
Anyone got any ideas that doesn't involve sticking something up the side as i don't want to damage it.
Also, i've read that i would need to put in a specific anti-freeze in rather then the standard that you would buy from from same Halfords? Is this true? If so where do i buy it from?
Cheers for any help
I assume you mean sliding cover - all i did was to tap the underside sharp with hand
and it freed it ( 3-4 times)
and i have used standard antifreeze ( its a standard car engine ) but hopefully bad
weather now over :thumbsup: any help
:yes: Thanks for that. I have managed to free the front sun-roof and my kids managed to dislocated the rear sunroof slider as well which i managed to do (took quite awhile).
As for the Anti-Freeze, thanks for that as it will save me looking around for the supposedly special one now.
Cheers
