Townace 1991 2.0Td Royal Lounge Won't Crank When Hot
Hi
I own a 1991 Toyota Townace Royal Lounge and runs very well and starts first time when cold but when warm the solenoid is heard clicking but the starter will not crank. If I wait about half an hour it usually starts ok. I was wondering whether the starter relay maybe sticking or if it's an ECU problem. I don't even know where the starter relay or ECU are.
Could anyone please help?
Hi There
Its a starter motor problem, common problem on this model.
My friend has a toyota imported Estima, and she found BBCSPARES were great, Mark @ bbcspares specialises in Estima, Townace and Granvia's.
Give him a call see if he can help you out.
www.bbcspares.com
01442 842007
Spk to Mark
Good Luck.
Hi There
www.bbcspares.com
01442 842007
Spk to Mark
Good Luck.
Thank you for that but the guy I purchased the Townace from knew about the problem and had a recon starter fitted so this has led me to think it maybe the solenoid/relay sticking when hot. When it cools down though it starts fine, so how can it be the starter?
