St182 Windscreen Washer Bottle/motors Removal
tr0ub1es0me
Hi. I own a UK 1991 2.0 Celica GTi-16 liftback model, and need to remove the water bottle and motors/pumps assembly for the windscreen washers. However, I'm unsure of the best way to access it. The ABS pump?/acuator? is above the waser bottle which prevents access from the top, unless it is removed. The alternator has already been removed which means at least that is out of the way, if accessed from the top. I've read in some threads here after searching that on some other Toyota vehicles the pump and bottle can be accessed for removal/replacement by removing the bumper, or jacking the car up and removing the wheel, etc. I don't know if it's the same for the Celica ST182 though.
What is the best way for me to get to it? I'm probably going to remove the ABS thing anyway, but I'm also not 100% sure how to get that off either. Unfortunately these two separate things are not covered by the Haynes Repair Manual that i have.
Thanks!
on most celicas you remove the wheel , remove the inner wing liner and the washer bottle is right infront of you .
