Water Escaping From Engine
nick w
I've got a gen 7 vvti 140hp Celica.
I keep having to top up the engine coolant.
Thermostat is working fine, and bled the coolant while checking for an air block.
Any suggestions as to where the water could be going?
Engine running fine, just the obvious oil burn off that's to be expected from this engine.
Try to trace where the leak is coming from when it is at idle.
Also check the oil filler neck for "mayo" to see if it could be the gasket.
look for steam from the radiator area and the filler cap of the header tank when its hot.
could be a weeping pipe , core plug etc - lots of possibles but only 1 cure.
