Oil Problem On Vvti Engines
farrow
Hello, the reported excessive oil consumption use on vvti engines, is this on all capacities or just the 1.6 and 1.8ltr units? Thinking of buying a 2.0ltr and unsure if this is affected after reading through some of the topics. Thanks
I know that the 1.6 suffers particularly badly. It's a problem with slightly undersized piston rings. They aren't at any risk of failing or anything its just a little more oil gets burned.
My 2.0Ltr uses requires no topping up between services.
Fitter
My 2002 1.8 vvti uses absolutely no oil between changes & stays very clean, too, an indication of no blow by on pistons & rings. It has only done 35000mls but I am very pleased with it.
I think the oil problems were only on the ZZ engines, being the 1.4, 1.6 and 1.8. The 2.0 is think is a 1AZ engine, which didn't suffer from the problems.
Has far has i am aware it is only zz engines, me and my dad have both required engines to be replaced.
